NOVA Hayaaaaaabusa 2008
Valdicreidison Letisgô
Registrado em: 24 Dez 2007, 16:03
Mensagem por Valdicreidison Letisgô »
1340cm3 in-line 4-cylinder fuel-injected liquid-cooled DOHC engine built to deliver a broad wave of torque for effortless acceleration while reducing emissions.photo 1
Hard, smooth chrome-nitride Physical Vapor Deposition (PVD) coating on the upper compression and oil control piston rings reduces friction while improving cylinder sealing.photo 2
Suzuki Composite Electrochemical Material (SCEM) cylinder plating improves heat transfer, durability and ring seal.photo 3
U-shaped cutouts in the cylinder-bore sides allow air below descending pistons to escape to adjacent cylinders to reduce internal pumping pressure and mechanical power losses.photo 4
Lightweight titanium valves allow use of lighter valve springs and higher lift while maintaining accurate valve control. Iridium spark plugs produce more complete combustion. photo 5
Curved radiator with a compact, dense-core design and engine-management-computer-controlled two ring-type electric fans mounted on the rear of the radiator, increasing the control accuracy and keeping engine temperature stable.photo 6
Suzuki Dual Throttle Valve (SDTV) fuel injection results in improved power delivery, a more linear response, better mileage and less emissions. This system uses engine-computer-operated secondary valves to maintain optimum intake-air velocity for maximum combustion efficiency.photo 7
Dual large-volume triangulated and tapered mufflers, shaped for increased banking angle and cornering clearance, enhance power and reduce noise.photo 8
Suzuki Drive Mode Selector (S-DMS) enables the rider to choose from three different engine power characteristics according to personal tastes and riding conditions. It offers enjoyment of top performance in a wide range of riding situations.photo 9 photo 10
Inverted cartridge front forks featuring Diamond-Like Coating (DLC) surface treatment to reduce stiction and improve reaction to small surface irregularities.photo 11
310mm (12.2-inch) dual-floating-disc front brakes with efficient, race-proven aluminum-piston, radial-mount brake calipers, and 260mm (10.2-inch) single-disc rear brake with single-piston brake caliper.photo 12 photo 13 photo 14
Standard-equipment steering damper.photo 15
Vertically stacked headlight featuring a projector high beam and a halogen-bulb multi-reflector low beam.photo 16
Bright, durable LED taillight, with clear inner lens and red outer lens.photo 17
Four analog gauges including step-motor-driven tachometer and speedometer. Round LCD panel includes clock, gear position indicator, S-DMS map indicator, odometer and dual trip meters. Engine-rpm indicator, programmable to blink or stay on between 4,000 and 11,500 rpm.photo 18
Felipe Ghost Rider
Registrado em: 23 Dez 2007, 23:31
Re: NOVA Hayaaaaaabusa 2008
Mensagem por Felipe Ghost Rider »
fica muito boqueta um painel que não passa dos 280km por hora.
Se ela passa, por que não colocar?
Pois esse lance de nao incentivar ir a essa velocidade nao cola pra mim.
Fiuuuum
Felipe Ghost Rider escreveu:fica muito boqueta um painel que não passa dos 280km por hora.
Fiuuuum
Ô Kamerad nº 24(*): o Sr. é um fanfarrão, pede prá sair, eheheheh... olha de novo, pois tem mais dois "risquinhos" após o 280...
(*)esse é o seu nº de registro no "novo M@D" :lol:
Felipe Ghost Rider
Fiuuuum
sim Kamerad 11 (um atras do outro), o lance eh que nao tem o 300 no painel, e risquinho eu ponho ateh com corretivo. eheheh
eu daria graças a deus de ter um velocímetro de verdade em vez de um lcdzinho digital
show de bola esse painel da busa.
[]x
Lucas_BH
Registrado em: 23 Dez 2007, 21:30
Mensagem por Lucas_BH »
bacana...
só achei um pouco estranho a traseira!
T+.
:twisted: :twisted: :twisted:
Imagem Imagem
Neto
Mensagem por Neto »
realmente... sem o 300 no painel fica sem graça rs :-D
Fender
Mensagem por Fender »
Se eu gostasse de esportiva e tivesse $$$ não seria por esses 300 no painel que não compraria essa moto... :-D
Acho muito bonita, mas já passei da idade...
Felipe Ghost Rider
Fender escreveu:Se eu gostasse de esportiva e tivesse $$$ não seria por esses 300 no painel que não compraria essa moto... :-D
Se eu tivesse grana pra ter essa moto, ja sairia da concessionaria com escape, dyno, k&N e um painel com velocimetro de 320 km/h. :twisted: :twisted:
Mosimann
Registrado em: 25 Dez 2007, 04:21
Mensagem por Mosimann »
A notícia pode não ser nova, mas que é um prazer ver e rever essa moto várias vezes, isso é. ;-)
Coiote
Registrado em: 26 Dez 2007, 10:56
Mensagem por Coiote »
Show Suzuki comanda mesmo :-D
Coiote
B650S
White Side of the Power
Juca
Registrado em: 26 Dez 2007, 07:35
Mensagem por Juca »
Interessante, tem até um "espelho" ali no meio do painel 8)
RRRED
Mensagem por RRRED »
Vi esta de perto este fim de semana.
Difícil é saber onde é a frente, onde á a traseira na hora de subir!
:-D
JaZz
Mensagem por JaZz »
No lado esquerdo do painel, abaixo do marcador de combustível, aquilo seria luz de quê?
Não vi sinal de nada e imaginei ser uma shift light...
Emerson
Registrado em: 26 Dez 2007, 12:37
Mensagem por Emerson »
A haya ta muito bonita, mais a minha RF900 marca 300tão no painel.... :lol: :lol: :lol:
Emerson Librelato - Motoclube Descendentes da Estrada - Gravataí - RS
RF900R
EN125 yes
GyG@
Registrado em: 25 Dez 2007, 11:27
Mensagem por GyG@ »
Uma verdadeira obra de arte!!!
Mas pra mim seria uso de força desnecessário, já que não vejo motivos para andar além de 140 km/h! :no:
Editado pela última vez por GyG@ em 26 Dez 2007, 15:01, em um total de 1 vez.
Tenho uma vida equilibrada... Ando sobre 2 rodas!!!
blasques
Registrado em: 26 Dez 2007, 10:27
Mensagem por blasques »
Jesus Christ! Essa é a Deusa, sou apaixonado pela Monica (GSX750F) e pela Hayabusa então sou suspeito à falar, mas como já disseram os amigos... Um verdadeira obra de arte!
Editado pela última vez por blasques em 26 Dez 2007, 14:45, em um total de 1 vez.
Todo rolê é unico, toda moto é exclusiva...
Respeite todas, ame a sua!
Guerreiro-BA
Registrado em: 26 Dez 2007, 08:50
Tesão de moto...
Mensagem por Guerreiro-BA »
Essa com certeza vai ser a sucessora da F....... :-D :-D :-D É muito linda!!! Muito máquina!!!
---ooO--(_)--Ooo--
Cid Guerreiro
Kawa Ninja Verde ZX14 2013
Kawa Ninja Preta ZX14 2010
Kawa Z750 Branca 2010
Suzi GSX750F Preta 2007
Suzi GS500E Preta 2003
RRRED escreveu:Difícil é saber onde é a frente, onde á a traseira na hora de subir!
:-D
;-) :-D
locatelli
Registrado em: 26 Dez 2007, 08:22
Mensagem por locatelli »
Essa laranja com preto ficou massa..
Essas outras cores parece que esta faltando alguma coisa...
Grupo Perdidos no Asfalto Canoas-RS
